-How to fix Super little bit water on charger HP
WetLaptop
16
Hello i was on my office and drinking Plus Juice Apple then my glass of juice was pulled of to the charger by me accidentaly i unplug the charger then i use rice method i see its only super small little bit of water goes on the wire onto inside can i use it again? I am afraid to use again cuz i dont want my house get ruin by fire
https://i.imgsafe.org/8c59d641db.jpg
When did it happen? If it happened very recently, give it a day, don't use it. It will dry off. Once it does, try plugging it on. Make sure the switch you put in has proper earthing.
I think nothing will go bad. Good luck though. Be safe. :)
josie_raye23
