How to replace your Razer Blade 2016 battery
Windows Central
WinC Bot
Staff member
Dec 17, 2013
74,115
73
It only takes around 15 minutes!
The Razer Blade 2016 is a fantastic laptop that came out a couple of years ago. It costs a lot to send the device back to Razer for a battery replacement, but you can always buy a third-party battery and replace it at home. Below, you'll find a step-by-step guide on how to do exactly that. When you're looking for a third-party battery, you'll want to find one that provides screwdrivers because Razer uses some unique screw holes.
Before you begin, remember to shut down your laptop completely and remove the charger.
Full story from the WindowsCentral blog...
jawkinshere
