How To turn it ON !!! Dead battery for several days
Black Buzzard
24
Im using lumia 1020. It has been switched off for few days due to empty battery . But now i cant turn it on. I tried different ways even i tried with nokia software recovery tool. But i cant. Can you please let me know an effective way to make it alive ? :crying:
Well from the description, it looks like your battery circuit is off. When that happens, it refuses charge until you charge for a few hours/a day
i have similar issu with my lumia 1020,when you connect the phone to pc turn windows light on screen for few second?
ok,i think we should flash it,and i fear logic board be fault....that when i connect the pc not recognized by pc and turn the light for few second and nothing act .....can you call with nokia center in your country???
Is it on? If not, then plug it in for 30 minutes, unplug, then again for 4 hours. If not, then soft reset. If not, then try a hard reset. Then I'd assume it's a hardware problem
I know my 1020 locks up and acts like its dead, but holding "Volume Down and Power" for 15 seconds always resolved mine.
Charis Cheng
