Inexplicable Battery Drain
akiman911
78
Out of nowhere.... was in standby overnight for 8+ hours stayed at 100%
Droping 5-10% every hour since then doing absolutely nothing
Background apps (none of which ever seemed to create problems):
battery level
Weather
Wikipedia
Wifi and celuar are on....
Nfc/location/ etc all off
It is as if I drain more battery standby then I do when I actually use it, very odd, anyone experience anything similar?
Would a hard reset help this? I tried soft reset a few times (holding 3 buttons) to no avail
Any input is appreciated,
Thanks
