Lian Li's Strimer LED cable will light up your rig.
For the last few years, component manufacturers have been adding RGB lighting to everything: memory modules, keyboards, mice, cases, motherboards, video cards, and even PSUs. Lian Li is going one step further and launching power supply extension cables that feature RGB LEDs.
The Strimer is a lighting module that can be hooked up to your motherboard's 24-pin connector or your video card. The Lian Li Strimer is compatible with every PSU, and the company says its mounting mechanism will ensure the cables fit securely within your existing setup.
Full story from the WindowsCentral blog...
