Lumia 950 Wireless Charging Problems
CountStyrofoam
16
Anyone else's Lumia 950 not working well with wireless charging pads?
It worked like a charm on my Icon and it seems to barely take / give a charge on the 950.
Which charging pad ? I have been using both Samsung fast charging wireless charging pad and the old Nokia DT-910, both worked just fine.
Another possible reason is the Qi charging receiver for 950 is actually on the removable back, so re-install the back firmly make sure the contact pins are connected . So maybe try use NFC since that is also on the back cover, if that dosn't work, then definitely the back cover is not installed properly.
Same problem here with CR-200 charger for car. Previous Lumia 930 was charging flawlessly on it, Lumia 950 barely gets anything. Gonna test it out on another QI charger when get back home
My 950 has the same problem to recognize the charging pad that used to work well with Nexus 4.
No problems using the DT-910, but I haven't tried any other chargers. A standard question, do you have a case/cover on your phone? This can significantly reduce the wireless charging capability in the QI charging environment.
It looks like the issue was gone after I enabled nfc. Will keep testing later
I use the DT-903 charging pad to charge my Lunia 950, and it works perfectly, charging relatively fast.
I use a generic charger and it works just fine with my 950 as well. One thing I have found is that if the coils do not line up well, charging suffers a lot
tnomtlaw
