My lumia 920 screen inside have water vapour!!!!!! how to solve ??? HELP!!!!!!!!!
My advice would be to put some uncooked rice into a tub and place the phone in the tub (obviously turned off) for a few days.
how many days ? its works?
Look it up online, im sure it varies depending on how much moisture is trapped but uncooked rice is supposed to draw out moisture from electronic devices. The only other issue is depending on how long the moisture has been inside the device it can cause corrosion to the device so you need to try this asap.
sun is the worst answer, i did that and now my phone is dead. waiting for the people to call me back and tell me how much will cost to fix it.
When i took my 820 swimming with me i put it in dry rice in top of my Tivo... Overnight it bought my phone back to life...
Dry rice in an enclosure or better yet silica bags as quick as possible as oxidation is brutal for any electronics and gets worse by the hour.
josie_raye23
