my surface pro 5 weird battery behavior
Status
Not open for further replies.
Friday20
Hello everyone I'm using surface pro 5 now and usually I can get around 5 hours of battery life.
I've done everything to improve the battery life and I install the battery bar.
I discover that when my battery is above 50% ,discharge rate will be high like 20000mw or higher all the time no matter what am I doing and when the battery is below 50% ,discharge rate suddenly low like 2000mw or lower or higher up to task.
I underclock the CPU maximum to 90% and set everything to low as possible in power option ,disable service ,background app ,update driver etc.
I use windows 10 1903 build 18362.387
i5 7300u 4gb
I think the problem maybe the driver but which one ,that when its see my battery is above 50% its boost things up.
Status
Michael Niehaus
