My Surface says it is plugged in but not charging. How can I fix this problem?
my surface says it is pulgged in but not charging. How can I fix this problem?
I've tried several fixes but nothing seems to work this time
Re: my surface says it is pulgged in but not charging. How can I fix this problem?
If you have eliminated the cable and the charger along with the outlet then it would be the charging port on the surface that is broken and will need fixing.
Is it already fully charged or ~98%? then that's normal.
Does it happen at specific times or activities?
rajdipprimeview
