Need help with edge casting to xbox one failing
Evan Otis
I am trying to browser stream (In this case History Channel) from my PC (Win10) to my Xbox One. The first problem would be that every time there is a commercial it stops the stream on my Xbox forcing my PC to go to the next episode like the last one had ended, and returns to the app on the xbox like the stream was stopped "ended". But I also can't just reconnect right away either, it can take up to about 5 tries to get it connected again, either it just says "starting" on my xbox, and acts "connected" on my PC while both screens are black and I have to disconnect and try again, or the picture will load on my xbox but be frozen until I disconnect. biggest issue would be the commercial's ending the stream, but also not exactly fun having to try so many times to connect. I could be wrong but I believe that the issue is on the PC end.
Any help would be amazing.
Thanks
I suggest you use the "Windows Feedback Hub" to report these two issues. I just filed one bug about having to keep casting. You may want to search for that, upvote and file another about the issues in reconnecting.
I doubt anyone here can fix these for you as they sound like OS limitations/issues. But I'd love to hear if someone has seen this and worked something out.
TheDonCoffee
