Problem with glass at top of phone?
octavian90
101
Hard to describe, but basically a rectangle of glass around the earpiece/front camera is different from the rest. I can't clean it off completely, and it is a little 'cloudier' than the rest of the screen. Its a perfect rectangle too which is weird. Did they make a mistake putting a coat on the glass or something?
Mine has it as well.
There was another thread talking about this but I can't seem to find it right off hand.
Isn't it some kind of sensor? My htc hd7 had it but it was two circles rather than a small rectangle.
Im positive is the distance sensor that causes the screen to go blank when its near your ear. I could be wrong though :(
that's the light censor.
I don't, but just noticed dust in the front lense 😒
Sent from my RM-820_nam_att_100 using Board Express
that's the proximity sensor. it turns the screen off when it detects something close during a call (such as your cheek) to save battery.
That's not what he is referring to.
Here is a pic of mine. You can clearly see a difference in the glass. It goes from the speaker to the camera to the sensor.
Is it a cyan only thing? I'm pretty sure I've seen cyan ones without it. Maybe we all got a bad batch. Will check att store today.
I have a similar thing. Directly above the cutout for the earpiece there is always a smudge on the glass. The only way to clean it is with a microfiber cloth. If I run my finger across the whole width of the phone along the top edge of the screen, the smudge returns, but the rest of the screen I touched remains spotless. Must be an area without the coating.
PS I also have some areas on the black case that cannot be cleaned--near the sim door. The black color is a little different than the rest of the phone. It's been that way since unboxing.
I made the other thread about. I received a replacement phone from Nokia due to battery issues again and this new cyan l920 does NOT have that weird rectangle that goes from the earpiece to the O in Nokia. Also it doesn't flex or creek by the bottom left speaker like my other one did
My last cyan also had slight discoloring on the back
excellent. Unfortunately I'm outside the replacement window but will ask for a reconditioned one. Hopefully will be fine!
it is normal because the sensor dont want to be covered to senses correct lighting reading. Am i right on this?
I'm amazed as to how many people are unable to actually click on a link and open their eyes. Once again, it's the glass, not the sensor
alcorrr
