Welcome to the all-new Windows Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues, please let us know in this thread!
Was going to post this deal, but since you've got that covered I'll add to this.
If you are already a subscriber, the additional $30 you need to pay up front will just be a credit to your monthly bill. To do this, you'll need to log into your Cricket account and upgrade your phone. Select the Lumia 650 and you'll see the $30 line item with a note that it will appear as a credit in your account. At the end, you'll be paying $1 since you're getting the $30 posted to your bill.
SIM/network unlocking I'm unsure. What proof are they basing the unlocked FW update/install on? Installing the unlocked fw will not sim unlock the phone. If that's what you're asking...Has anyone had success in unlocking these through third parties? Also from a couple of posts here, looks like the firmware cannot be updated to the unlock 4R US version, can someone confirm this?
Are you sure that can't be added via regedit either?I know they (Cricket) never pushed the DTtW firmware advance.
I'm aware of the difference between SIM unlock and flashing a different firmware. I just combined 2 questions together in my post.SIM/network unlocking I'm unsure. What proof are they basing the unlocked FW update/install on? Installing the unlocked fw will not sim unlock the phone. If that's what you're asking...
Ok, I was pretty sure that was two questions. Just making sure.I'm aware of the difference between SIM unlock and flashing a different firmware. I just combined 2 questions together in my post.
Either way, I'll know in 2 days if the flashing works, I won't be surprised if it does based on prior experience. SIM unlock might be a hit or miss depending on some eBay sellers.
...I'll know in 2 days if the flashing works...
Received it yesterday. I enabled dbl tap to wake while on fw:01078.00036.16035.40009, basically stock cricket fw and newest w10m build.
So far so good.Any bugs, issues, defects or problems with it? Glad DTTW works. Use it all the time in my L640
Proper DTtW regedit is what it needed. However using InteropTools there is a toggle to set the hw to recognize it is dbl tap capable, and I toggled that too. Otherwise like mentioned I think the feature is not there by default.Glad DTTW works. Use it all the time in my L640
