Review: Building a PC? You should consider NZXT's RGB & Fan Controller.
Windows Central
WinC Bot
Staff member
Dec 17, 2013
73,354
57
Light up your PC the right way.
Modern motherboards may come with RGB addressable headers, which allows one to synchronize additional lighting accessories with those found on the main board itself. But if you prefer to go entirely external, NZXT has a controller for you. The NZXT RGB & Fan Controller does precisely what the name implies.
Connecting fans and RGB strips or other lighting-enabled components to the hub allows for the controlling of everything using NZXT's CAM software. It's a little on the pricey side, and you don't get any RGB strips or fans included as standard, so is this little device worth it for PC system builders?
Full story from the WindowsCentral blog...
COME ON WIN ANDROID (ADI)
