- Dec 17, 2013
- 79,128
- 167
- 0
Capable of handling up to 190W of heat, the budget-friendly be-quiet! Shadow Rock 3 is ideal for a mid-range PC build.
The market for affordable, mid-range CPU coolers is rather busy and be quiet! thought it would be a good idea to roll out the new Shadow Rock 3. This air-cooler is rated at 190W TDP, meaning it should be able to handle overclocked mid-range processors like the Intel Core i5 and AMD Ryzen 5, as well as more enthusiast setups.
If the Dark Rock Pro 4 is a little overkill at a whopping 250W TDP, the Shadow Rock 3 should be a much better solution for your system requirements.
Full story from the WindowsCentral blog...
