Samsung ativ s t899m roaming problems-how do I fix?
WPCentral Question
Hi,
I've bought 2 samsung ativ s t899m (Bell Canada) and took them overseas.
From the start I've encountered a similar problem in both phones: there's a network (carrier) connection problem. Every now and then I'm unable to make an outgoing call and and error message appears (unable to connect to network) but at the same time I have no problem receiving calls, sending and accepting messages (SMS & MMS) and using data.
I've tried changing carriers but the problem consists.
When I reboot the phone I can again make outgoing calls.
Carriers technical divisions claim there's a problem with the phones (maybe API software issue) but can't be sure because it not there phone.
Another Tech guy told me it's a roaming problem but had no idea on how to fix it.
Any ideas?
Thanks!
Devices are factory unlocked. Roaming is enabled.
I'm now in Israel and the problem consists with both phones on 2 carriers - both are fully adequate with phone bands.
I'm using a local carrier micro-sim.
OS ver.: 8.0.10521.155
Firmware ver.: 2212.13.11.2
Bootloader ver.: 1308.14.16
SOC ver.: 1.5.32
Samsung Canada suggested a hard reset but said there's no way knowing if it'll solve the problem (seems like a s.o.p for them...)
josie_raye23
