- Dec 23, 2014
- 10
- 0
- 0
Surface Pro 2 and Audio through HDMI
So I've had this issue with my SP2 since...I want to say since the last major update. I frequently use my SP2 to watch TV through various streaming services and since that last major update it takes a lot of work to get audio to come through to the TV through audio.
To go back a bit, I've used the microsoft Displayport to HDMI adapter since I bought my SP2, about two years ago. At first I thought it was my HDMI cord, as I have had to replace it before, so I got a new one, same problem. I first noticed the problem when I was out of town working, so I thought maybe the hotel TV had an issue. I got home, plugged into the same TV I have had since I got my SP2, and same issue. No audio. Display works fine, windows says audio device is there but no sound. Says sound is playing, but nothing.
I tried the HDMI cord I use for my Xbox, and both ports on the back of my TV. I went and bought a new DisplayPort to HDMI, same problem.
Right now I have to boot up windows, do a test to see if audio is working (it never works on the first boot). Then I reboot my SP2, do another test, if it doesn't work I switch the default format around, and usually that gets it. I've looked around a few places and have not found a definite answer. Hoping for some help here.
Thanks.
Thanks.
