WPCentral Question
Getting a Surface Pro 3 soon, but wanted to know somethings before I get it. I don't want to ruin the Surface Pros battery and want to make it last as long as possible.
1. Does anyone know whether you have to charge the device for a certain amount of hours once you unbox it, or doesn't it matter when you put it on charge or take it off. Like when I first charge it can I charge it to like 50% whilst using it and then lets say want to go to another room and still charge it, can I take it off charge and resume charging in the other room without ruining the battery?
2. That leads me on to my second question. Can you use the Surface Pro 3 whilst charging it? So lets say I know I'm going to be working on a certain document all day would I be able to keep it on charge whilst I'm using it without overcharging or ruining the battery at all?
3. Do you have to charge the Surface to 100% in order to 'look after' the battery? If so does that mean that you need to let it (almost) completely die and then charge it?
4. Final question... Does leaving the Surface on charge for a long period of time ruin the battery? So let's say I leave it on overnight to charge, will that ruin my battery?
I know that's a lot of questions, I just don't wan to ruin it since it's not cheap and you can't manually replace the insides. I'm sure a lot of other people want to know too.
Thanks in advance
Thanks in advance
