- Apr 25, 2017
- 51
- 0
- 0
My surface pro 4 is always dead and has to be plugged in. This is my third one so I know its not that I just got a bad one. Is the lap top better ?
Welcome to the all-new Windows Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues, please let us know in this thread!
I take online classes so I need it on for hours. I have only had It for maybe 3 weeks so I don't think I need a new battery. Its brand new.
Surface laptop IS definitely better in terms of battery life.
I suppose surface laptop is better to use as the battery can be replaced easily.
Of course yes! But its far better than a tablet pc like surface pro 4
Surface Laptop is supposed to come with a LOT better battery life than Surface Pro 4. Battery consumption also depends on the model that you have and the apps that you're running + screen brightness is a big deal at this high screen resolution.
So many factors but generally yes you should get better battery life out of it. I would suggest getting a dock so you can keep it plugged in when you need it for class but you don't need to have your charger with you all of the time. As long as you do most of your classes in the same place everyday.
