• Welcome to the all-new Windows Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues, please let us know in this thread!
Thanks to the Other Storage problem, I will have to hard reset
segadc
91
I hate to do this but with 8.48gb of other storage and rising, I have less than 700 MBs left. I barely have much apps and use SkyDrive and Xbox for my storage needs. Anyway so besides game saves (this is huge :( ) and Live Tile placement, what else will not recover? Also if I do this and turn off Skydrive auto upload, will my other storage rise as fast or at all? Should I wait for a fix which may take a while? Thanks for reading. I can't believe nobody at Microsoft noticed this in their testing!
Narse77
586
You can redownload your apps. As far as contacts etc, if you had it set to backup you should get those back. Also try the app Shrink Storage from the store. It should get you a couple GB back. I know Nokia has a firmware rolling out now to fix this issue, hopefully HTC or MS can get one out soon also. The other storage problem is a real issue.
Shrink Storage | Windows Phone Apps+Games Store (United States)
segadc
91
I tried shrink storage and it doesn't work for me. Seems to release about the same amount of storage that I had before using it. Also tried the trick to move all pictures and videos from camera roll via Skydrive to another folder on skydive. My phone is starting to lag a little which is really something I don't see often on WP8.
wilsey
220
I'm not sure if moving all the pictures to another folder on Skydrive can work. Try to turn off the auto-upload to Skydrive and only upload the photos that you think it is important. Because uploading photos+videos to Skydrive is one of the main reason why the Other Storage keeps rising.
Maybe you can try to copy all those pictures in your Skydrive folder to your computer first. And then try to delete the photos inside the Skydrive albums from your phone.
I believe it's the thumbnails images that we see inside the Skydrive folder that use up a lot of the Other Storage, especially if you have a lot photos uploaded to Skydrive.
Stu Malin
44
I have a feeling its not caused by Skydrive. I'm leaning towards the thumbnails that Photos hub hangs onto from all Facebook, Twitter and Skydrive albums. I deleted a load of music and my Other reduced by nothing. Will keep investigating maybe by deleting some of the photos I keep on FB
wilsey
220
Yeap, it's from Skydrive. Joe Belfiore mentioned it before. He suggested to turn off the auto-upload to Skydrive.
And that's what I said earlier, it's the thumbnail images that you upload to Skydrive that might use up a lot of the Other Storage.
tissotti
1,105
Apparently the other storage is normal according to Microsoft after i emailed them
Well it kind of is normal, but it's still a problem. Belfiore already said 2 weeks ago that will be fixed on a update.
Nokia has delivered or is rolling it out at the moment to its own fix to its Windows Phone 8 handsets already.
segadc
91
I deleted this folder with videos that showed up in the skydrive albums but made no affect. Also as many pointed out, after deleting apps/games, there is always left over data. I just wish there was a way to keep game saves. Its the only thing keeping me from hard resetting...
anon(5335899)
292
Assuming we're talking about a WP8 phone here, just connect to a PC and copy some large files (such as movies) to the pone. This will reduce the other storage segment as intended and release space. Also copy images from the phone, and back if required, will release space.
There is several apps available, like shrink storage, to resolve this and the coming Nokia Firmware update will also fix this.
HNNNNNGHHH
182
This problem also extends to WP7 devices, especially when application installs fail, leaving the installer in the "other" portion of the memory.
If Microsoft doesn't take action very soon, considering the fact that even this problem is still present in WP8, there will be even more WP users complaining about this issue.
pffloyd
So, here's what what I did to get Shrink Storage to work.
1) I turned off auto upload to Skydrive.
2) Ran Shrink Storage using the instructions provided
3) saved about 2.5 gb
segadc
91
Finally did a hard reset. :(. For the most part everything went smoothly. All the apps I believe downloaded. Text and some settings carried over. Of course lost most of my game saves. :(. Microsoft better give us the cache cleaner soon and fix the problem in the next update!
yanzfoot
5
Those new Gameloft games, takes a lot of "other space" storage. 2 hours playing Asphalt 7, and the "other space" went up 600 Mb
uopjo6
171
Auto upload off. Shrink storage used to death. System takes up 2Gb and other storage at 4Gb. Guess how much I have left with 0 games installed? Less than 800Mb. I can't install one damn asphalt game I believe MS has done nth! No ur storage check thing cleaned out 200mb only. Its ridiculous out 200mb only. Its ridiculous!
crash1989
1,491
I read it is due in GDR2 , hope they really fix this. I don't have it as bad as the OP, but I have taken all steps to prevent it from going out of hand.
