The [URL="https://www.amazon.com/NOVOO-PowerCube-Ultra-Compact-Compatible-Smartphones/dp/B07JZP287T?mnsid=mbnx3-20&tag=mbnx33-20&ascsubtag=UUwpUvbUpU3802944]Novoo 10000mAh USB-C PD portable charger[/URL] is down to just $13.99 at Amazon right now. The battery pack normally sells for around $22 and has never dropped this low in the past.
[thrifter: 176141 template:reco cache:reset]
This power bank is meant to be super compact. It is smaller than a credit card and super lightweight. You'll be able to carry it with you, whether that means storing it in a backpack or just putting it in your pocket. That makes it super easy to top off your phone while you're sitting on the subway. Or maybe you can use it to charge your device in a discrete way while sitting in class or a meeting.
Full story from the WindowsCentral blog...
