K kishorsomu New member Jul 12, 2013 2 0 0 Jul 12, 2013 #1 hey in my new nokia lumia 720 volume decrease control is not responding what to do ??
stmav Retired Moderator Sep 18, 2012 3,684 0 0 Jul 12, 2013 #2 You might try a hard reset. If the volume still doesn't work after that, you should see about getting the phone replaced or repaired.
mase123987 New member Mar 1, 2012 3,118 0 0 Jul 12, 2013 #3 I would hard reset. If that doesn't do anything, return your phone and get a new one.
Sagar187 New member May 14, 2013 12 0 0 Jul 12, 2013 #4 Switch it off and switch it on again. Then try. If it doesn't work then do a soft reset. If that doesn't work, try hard reset. If that too doesn't work, return it.
