Wall Charger / Car Charger Compatibility ?
mayoo
83
I have Wall Charger and a car charger from blackberry. is it ok for using them on Lumia 900 ? Does anyone know what the Amp Specs Lumia needs ?
For the 800 they recommend 1000mA. I would put it like this. You can use them, but it is recommended to use the original charger as main charger. I think my BB chargers are only 750mA but I also still use them for the Lumia if they are closer... Bear in mind that a USB port in a PC only gives out around 300mA.
It will take a little longer to charge and My experience is that the charged battery lasts longer when charged with a 1000mA (Or my 2000mA iPad charger)
So, it can be used. But it is not the best option.
Sent from my iPad using Tapatalk
Do you know what the included charger does? What MHA does it charge at.
5V @ 1A; same as Apple A/C adapters for iPods/iPhones. As long as you don't use a charger that is higher voltage it will be fine. Using an iPad charger that is 2A will charge it faster.
yagoldt
