Why does my sound keep going out?
I installed Windows 10 and my sound will be okay for a little while then it goes out, when I try to test it it says it is being used by another application. I do not want to have to reboot every time. I have done that and I am still faced with the same dilemma. Please advise I am getting frustrated and ready to go back to my previous Windows.
Quite likely you need new drivers. And an uninstall of the old drivers first.
[FONT=&quot]Check the OEM Support site for your device and/or the hardware component. Download new drivers if they can be found... Open Device Manager and expand the component category.
Disable the device and uninstall the drivers for it. Reboot. Run the driver install utility you downloaded from your OEM. Reboot, even if it does not advise you to... [/FONT]
RS-Driver
