I just got the Senna Case in yesterday after ordering it last week (dark brown):
http://store.wmexperts.com/sena-cases-vertical-pouch/4A25A832.htm
I was quite excited to get it! The current Body Glove side case I am using now is sort of a tight fit. And being a side case, it sort of sticks out both on the front and rear ends, so catches on too many things for my comfort.
Well, opening up the box (like a nice box you'd get with an expensive watch), I see this totally gorgeous case. And oh, the aroma of nice leather!!!!! It is extremely well made, as good as an expensive COACH Purse (believe me I know - had to buy enough of those every time in the dog house with the GF LOL). And the interior? So plush and soft, could not stop rubbing that
But now the problems happen . . . . .
The case is very well made as I said. Sadly though, the sides are solid (no stretch/spandex), so my Verizon TP2 is a slightly loose fit. I can still live with that, as I love this case! But then the tragic moment!!!!!!!! When I put the phone in . . . . . zip-zip, zip-zip. The magnets of the case keep turning my phone on!!!!!! Luckily I do have S2U2 on my phone, but still it starts up that screen and you keep hearing the keyboard open sound file played (I set that to on, and using the mechanical sound). Is there any way to stop/prevent this? If not, I will need to return this case (it was also the most expensive one at $39 too). And I really wanted this one because I just don't care for the looks or colors of all the rest of the top cases.
I just read the battery post. Am installing that disable slide to open CAB now. Will see how that works.
