1. skfny's Avatar
    There are a ton of 1340mAh batteries on eBay for the original (European) Touch Pro. Does anyone know if these will work with the Sprint version? I'm hoping they will since the Sprint version is slightly larger, but don't want to waste my $$$ unless someone can confirm.
    11-16-2008 07:50 AM
  2. bduerr1's Avatar
    These batteries are configured for both the Sprint Pro as well as the GSM Pro as well as both Diamonds. However, be very, very careful because many people have complained that some of these batteriess do not show battery level accuratly; if at all.
    Also, the extended batteries would work but there is no battery cover that will work with the Sprint Pro. And some have reported that their phones have gone bad after using these especially the one from Seidio
    11-18-2008 10:49 AM
  3. skfny's Avatar
    I purchased a 1340mAh battery off eBay. I'll report back on how it goes.
    11-18-2008 04:26 PM
