1. captaincalamity's Avatar
    With 8.1 I was able to connect to my in car system and use my nokia 930 to speak the navigation's through the car speakers fine, simply pausing the music playback from the 930 also.
    Yet with windows 10 a message appears on the car display saying call from cortana then a garbled voice says the directions, the music stops and doesn't restart, obviously this is impossible when the navigation's are every few seconds, the delay makes navigation useless.
    Is there a setting in windows 10 mobile that sorts this.
    01-04-2016 09:06 AM
  2. captaincalamity's Avatar
    I guess this is not happening to anyone else then
    01-05-2016 03:48 PM
  3. anon9776305's Avatar
    It is happening to me too. First you have to turn on Cortana and somewhere in there there is an option to have her read messages over Bluetooth. Once you get that set the messages will be read aloud. Now I need to figure out how to reply to text via voice.
    01-07-2016 04:35 PM
  4. Mark F24's Avatar
    Although I do not use a navigation app as you do, buy I do know first hand that Cortana is very unreliable over bluetooth using voice response.
    01-07-2016 06:58 PM
  1. Best in-ear handsfree for Nokia Lumia 630 DS
    By Nilayendra M Goon in forum Ask a Question
    Last Post: 07-29-2016, 05:29 AM
  2. Cannot connect the Lumia 950 to PC as a MTP device
    By XieminChen in forum Microsoft Lumia 950
    Last Post: 01-27-2016, 06:28 AM
  3. Wifi problem for Lumia 730, how can I fix it?
    By Windows Central Question in forum Nokia Lumia 730 & 735
    Last Post: 01-04-2016, 08:27 AM
  4. Replies: 0
    Last Post: 01-04-2016, 08:22 AM
  5. Continuum-capable Acer Liquid Jade Primo officially coming in February 2016
    Last Post: 01-04-2016, 07:11 AM
