1. WindowsCentral.com's Avatar
    We ordered everything we need to put together the cooling loop, including tubing, a cutter and reamer. Here's everything we received before getting started.
    As well as ordering everything you can see in a PC case with a completed setup — tubing, fittings, pump, reservoir and radiator — there are various parts and tools you need to help you connect all the components and ensure everything is secure to avoid leaks when assembling a water cooling setup. Liquid and electronics don't mix well, and that combination is absolutely the worst case scenario for any PC build. It's rare but can occur, so we'll need to make sure we're confident and take our time.
    Full story from the WindowsCentral blog...
    03-07-2017 07:10 AM
  1. Replies: 8
    Last Post: 03-09-2017, 11:00 PM
  2. Replies: 0
    Last Post: 03-07-2017, 06:12 AM
  3. Project Neon Fixing it all.
    By Damian Powell1 in forum Ask Dan!
    Last Post: 03-07-2017, 01:08 AM
  4. Bug-squashing update rolling out to the Xbox Insider Program's Beta ring
    Last Post: 03-06-2017, 06:40 PM
