After updating my 1520 to 8.1, my device sometimes suddenly getting so much hot at top left side (front and back) to a degree I thought its melded and the battery discharged 25% per hour. Happened 3 times in the first 2 days then I did a hard reset, then everything were ok for one day and again I did fully charge it (many settings turned off, wifi, data, bluetooth, location, nfc, IE syncing, advertizing ID) and also closed all apps running then put it into stand by, slept for less than one hour then wake up to find the phone very very hot to a degree I thought it will not turn on again (73% battery remaining) clicked the power button, black screen with stuck loading appeared, long pressed the back button to discover this is the start screen itself. Turned off the phone then switched it on again, worked again but instantly the heat rises again without doing anything. Turned it off again until it became cold and turned it on and again the heat return without opening anything. Then turned off backup settings and every other settings even the battery saver it self turned off from the background. Restart again still there is heat but after 5 min things become better. Now there is heat but don't know what to do.
My main concern hear is the phone being heated to this insane level. At this level of heat I'm afraid the phone makes fire while sleeping or explodes.
As much as I'm being crazy to have WP8.1 as much as I'm afraid from my phone now.
Anyone can help, anyone experienced this? Any suggestions?
So sad
So sad
