Title says it all, and I find it kind of weird. I started the process of doing a hard reset on my 925 because my battery was draining about 1% every 5 mins or so.
I plugged the phone in (at 70%), started the reset, and then when the phone restarted it was showing the low battery indicator and wont continue with the reset. Has this happened to anyone else? Kinda scary.
Update: did a hard reset with the button combo and it sprang to life. Seriously my battery is so effed. And this 925 is only a month old. Womp womp.
