1. Steve Adams's Avatar
    Is there any difference in battery life between the dark and light background on the 1020?
    jesusfreak420 likes this.
    12-17-2014 07:23 PM
  2. Asskickulater's Avatar
    depends:
    AMOLED screen: lots, always use the dark theme
    LED screen: makes no real difference
    12-17-2014 07:26 PM
  3. xandros9's Avatar
    depends:
    LCD*
    The 1020 has an AMOLED screen, meaning the above. Darkness highly recommended.
    More bright colors means higher power consumption.
    But if the battery holds up with it like that and you like the primary white look, feel free. I had a friend who used a Lumia 900 with the white theme. not ideal, but that didn't seem to stop her.
    12-17-2014 08:09 PM
  4. Stefan Holder's Avatar
    White theme will impact your battery..since more pixels are being in a constant "on" state, the draw will be greater.. By how much depends on the screen tech in use on your device. AMOLED yup.. Prepare to take a hit. LCD, bit as much..
    12-17-2014 08:14 PM
  5. Steve Adams's Avatar
    Ok, I do like the white theme, but I have not used it a lot just because of this. I will try and report back on drain.
    12-18-2014 04:44 AM
  6. Steve Adams's Avatar
    Ok, I am averageing 30 percent worse battery life with the light theme compared to the Dark theme. Back on dark. I can get through the day in dark and have over 60 percent battery left, I was down to 20 percent on light.
    xandros9 and revanthpallagani like this.
    12-21-2014 12:53 PM
  1. Why can't I type the question mark symbol when I try to type?
    Last Post: 10-25-2017, 11:04 PM
  2. How to unlock band 3 for Version M8?
    By frank zhao in forum Windows Phones
    Last Post: 12-18-2014, 06:58 PM
  3. WP App Design and Microsoft
    By mortici in forum Other Operating Systems
    Last Post: 12-18-2014, 02:51 PM
  4. Lumia Denim update goes live in Europe
    Last Post: 12-17-2014, 07:11 PM
  5. ProShot and SophieLens HD get minor updates but promise bigger ones in early 2015
    Last Post: 12-17-2014, 05:50 PM
