1. Slavko Petrovic's Avatar
    I am using L640 with W10M .164 build and I'm quite happy with it. This morning, when I opened "battery use" in "battery saver" I noticed that Mail and Calendar app drained aproximatley 45% of the battery, almost all of that as a background process. Later I contacted my friend who has L830 on the same build and same app is on top of his battery draining list, also as a background process. My questions are:
    -I doubt that is normal, so what should I do to decrese this abnormal background battery usage of the app?
    -If I just turn off ability to work in background for Mail and Calendar, is there any negative consequences beside need to manualy sync mail?
    Thanks in advance!
    04-08-2016 05:40 AM
  2. Chintan Gohel's Avatar
    Thanks in advance!
    You can safely disable mail in background and I would recommend it in fact. You would have to sync mails manually. That's not a big thing really. I do that 2-3 times a day and I don't miss much. Your battery will last longer of course and that's the good thing
    04-09-2016 09:15 AM
  1. I am using Windows 8.1 but on the Windows website it asks me to upgrade to Windows 8.1?
    By Windows Central Question in forum Other Operating Systems
    Last Post: 04-09-2016, 09:18 AM
  2. Replies: 1
    Last Post: 04-09-2016, 09:16 AM
  3. After the update, my Band 2 is constantly turning off thinking the battery is dead?
    By Windows Central Question in forum Connected Living
    Last Post: 04-09-2016, 03:23 AM
  4. In Windows Phone 8.1, .xap file not installed directly?
    Last Post: 04-08-2016, 05:37 AM
  5. Project Centennial desktop-to-UWP app converter now available for download
    Last Post: 04-08-2016, 01:42 AM
