Problem with a USB hub
redserpent7
68
Hi,
I just got an XBox One USB hub from amazon. It is working find and was able to connect several drives to it with no problem. The issue is that it seems it prevents the XBox from turning off. I use the Power-saving plan and if the hub is connected to the device the power brick turns off for about 5 seconds then it turns back on even where no drive is connected to the hub. One I detach the hub from my Xbox, it shuts down normally. Has anyone experienced the same issue? And how can I fix this?
Here is the Hub that I am currently using
Amazon.com: dreamGEAR Xbox One USB Hub: Video Games
EdgiHudi
