surface pro microphone issue!.. please help
alanxiaoyi
i got surface pro on the first day morning. and I found this microphone problem hours ago when I first make a Skype phone call with my friend.
My friend told me that there is very loud background noise. So I make some tests with several recorder app. The background noise is big enough to be noticed (very big in some sense) and sound like electronic noise. Like electromagnetic interference.
So I wonder if you guys have the same problem? or I guess I need to replace for a new one.... I always get bad luck on electronic stuff...
Could anyone try it out? thank you!
try an external microphone... it may be (it probably is) the inbuilt fan!
how do you like the pro?
Jam13
