- Aug 20, 2013
- 4
- 0
- 0
hello der , nw its around 1 month i got lumia 720 n frm d day i gt mobile battery lasts max of 1 day whereas i expected it to last 2 days :/ is this normal ? :/ wid data packet on it wont last even one day.. other than battery issue i luv my phonei need opinion abt battery :/ tnq
yea i use fb n wtsapp lot :/ n i've allowed only battery , wtsapp , wechat in background n blocked rest of d apps .. n i've set d preferences for email as u saidn d result is just nearly 27 hrs battery life :/
I have 3G data, wifi and Bluetooth always enabled (though not necessarily connected) on my Lumia 720 and it lasts generally about 48 hours before it needs a recharge (I'm a fairly light user). So your figures don't look right - unless you're browsing the internet or streaming music/videos for several hours a day, in which case you're getting what you'd expect.
The first thing to know is what apps are you running? Things like WhatsApp (the original version) caused excessive and continuous battery drain. The Facebook app has also been reported as causing battery drain on some phones.
You also need to look at what apps are allowed to run in the background. You should disable background running for any apps where you don't consider it essential.
Check you email download frequencies on all email accounts. If they're set to download on demand and you have multiple accounts, try setting them to download on a schedule (say every half hour).
Why , is there another version of whatsapp,sir?
Not sure, I don't use it. But I heard the developer was working on/releasing a version that didn't rely on an audio API hack to keep the app alive in the background. Not sure if this is now out. Perhaps someone who uses WhatsApp can confirm.
I don't think it is normal, I have heard from my friend who has L720, his batter lasts 3 days, bt my battery lasts 1 or 1.5days. I will sugegst u go to nokia care go for a thorough check up of this phone.
in the mean time u can try these to increase battery life:
1. switch of bluetooth, data connection, wifi when not in use.
2. use nokia xpress browser rather than UC browser, it will save battery
Battery back up will vary from phone to phone as no two users will have the same usage pattern. There a plenty of threads on how to improve battery life.
BTW what's wrong with IE?
