Issue:
HTC 8X, have had it for about a week now.
Using 3G works fine. You can turn 3G on and off and it will disconnect and then reconnect very fast. No problems.
If you leave the phone, with 3G off, for a period of time (I'm not sure how long currently) then try turning 3G on will result in nothing happening. This currently happens at leaving 3G off overnight. So again, if you don't have 3G turned on for a period of time, you won't be able to turn it on at all.
Restarting the phone solves the issue.
I'm going to run some tests, with a fresh restart, turning 3G on, then off and leaving for 30 minutes, then 1 hour, 2 hours, 4 hours etc to see at what length of time this issue starts to occur.
Is this an OS or Firmware issue, or possible a network one, and is anyone else experiencing it? If so, has anyone found a solution that works for this, or is it a case of wait for HTC to fix it? Has anyone experienced this on any other new WP8 devices?
It's definitely not a hardware issue. I've contacted HTC and am waiting for a response.
Thanks.
Thanks.
