Battery Drain Issue With DP?
wpfan1995
158
After updating with latest developer preview update wp8.1.1 build 14203.
I experienced some battery draining issues while using some social messaging apps like Whatsapp,Facebook Messenger etc.
Before update battery percentage dropped 1% to 2% while using social apps but after updating percentage loss was heavy about 3% to 4% per 30 minutes.
Is it me or anyone else noticed this battery drain issue after updating to build 14203?
her3814
149
Maybe you should try with a soft reset... If that doesn't help then go with a FULL reset .. I'm in the same build and no problems so far by the moment
Enviado desde mi Windows Phone usando Tapatalk
epmoj
9
Hi!
Yes! Significant battery drain on my 1520 after this update. Soft reset will not help. I don't think it's the social apps. Must be something else.
epmoj
9
I think it's the new Battery Live Tile. Removed it from the start screen and my battery drain got back to what it used to be.
Happy
