Will a Nokia 520 battery fit in a Nokia 620
Schnuffi
345
The 520 battery is I gather a little thicker but the other dimensions are the same but give you 1430 nAh instead of 1300mAh
Has any one tried this?:grin:
I_m_Snah
71
Yes, it fits. But you need to remove the padding (a sheet of paper) on the back cover to insert the 520 battery w/out any issues regarding on the back cover.
Sent via GaLAGxy Tab 2 7in.
Schnuffi
345
Thought as much I am a light user and the battery was not much of a issue. But with the latest update that I got yesterday (live in Germany just got the 8.1)
It might start to be a problem. I will go to Amazon and buy a battery and will let you guys know. It just upsets me a little if this thing fits and functions why didn't Nokia chose this battery for the phone it probable cost only 25 cents more :unhappy:
DrPendragon
