Can any body help on how to enable the in lumia 730
WPCentral Question
Settings-->Systemappplication-->touch option in the nokia lumia 730
when i am click or touch on the touch icon it is showing the same page again
can any body please help on this..
You mean it won't scroll between the systems page and the applications page?
Have you tried a Soft Reset? Hold the Volume Down + Power buttons until the phone vibrates and reboots. You won't loose any data, but it clears the gunk out of system memory.
Any other Touch issues? If worst comes to worst, make a back up and do a factory reset.
sixsigma
