Is my battery draining because too many processes are working at the same time?
because too many procceses are working in the same time
or battery is old
Re: because too many procceses are working in the same time
Indeed it is one of them.
But with battery saver you can check the app usage (foreground and back ground) . Also check I settings > email+accounts > how often it id synced.
If above is not an answer on your question. Please make next time your question more clear and or create an account on WC so you can reply on this post.
longinotti101
