Is sound recording using 3.5mm microphone adapter cable possible?
WPCentral Question
Sound recording using 3.5mm microphone adapter cable
I'd like to take a video with my lumia 930. However, I want to record the sound of this video using a 3.5mm microphone adapter cable. Is it possible?
jmshub
Moderator
Apr 16, 2011
2,667
Re: Sound recording using 3.5mm microphone adapter cable
To clarify, are you asking if you can plug a microphone into the headphone jack, or are you asking if you can plug some other recording device into the headphone jack to record the audio out to it?
DrPendragon
