How to fix outgoing call drop problem though phone showing full signal strength?
I am using lumia 630 SS in India. I have seen every outgoing call dropped in a particular area or region. But in this situation every incoming call is working fine for this phone. In this case i selected 3g for connection speed & automatic for network.
But if i select 2g for connection speed,this problem vanishes permanently.
I have seen in this region network providing 3g for data(internet), 2g for voice call.
Thats why in this region when phone is trying to communicate 3g freq for voice call,it is dropped all the time. But if select 2g for connection speed its working fine.
I am observing this everyday. It should be taken care of by phone itself.
Please take care of this problem for lumia 630.
email: asau_2007@rediffmail.com
No one here can fix that for you.... this isn't Microsoft.
​And the problem you've described sounds very much like a network issue - you should contact your cellular provider.
thti
