"Problem" with Edge
anon(10162577)
6
When i'm trying to access Windows Central or some other website, Edge is asking to download .htm file. So to access website I have to download this file and then open it. What is this?
That sounds like a bug or file association issue...
Edge shouldn't be asking you to download the website in order to view it.
Which version of Windows 10 are you running?
Are you on a insider build?
The easiest way to check is:
1) Windows Key + X
2) Run
3) Type in WinVer
Version .953
Not an insider
There was a cumulative update released, KB4015438 which would bring your version upto 969. Try updating, that may fix the issue you are experiencing with Edge.
Also did you use "registery cleaning" / "registery repair" application?
They usually wreak havoc with file associations.
Poohbear_25
