Problem with Fidme
ImmortalWarrior
523
Hey guys, just wondering if anyone else is having a problem adding cards to the wallet through Fidme.
Several weeks ago when I set it up I was able to integrate one of my cards into the wallet through the app. Today, I tried to add another and the option is no longer there. I even tried removing the existing card and re-adding it but the option no longer exists.
Anyone else experiencing this problem?
Hello ImmortalWarrior,
now you can only add some loyalty cards in the Microsoft Wallet : Marionnaud, Monoprix, Virgin Megastore, Le Club Accorhotel, Bizzbee, La Croissanterie. More cards will be available soon, gradually according to our partnership with retailers.
Hope you will not hold it against FidMe!
Any other question ? We answer you at support@fidme.com
Hi, thanks for the reply. I was emailing your support back and forth about the issue and they've been very informative. Thanks!
Hello!
Fidme, do you see a possibility of adding 'GameStop''s reward cards able to be added into the wallet at any point? That would be fantastic, as opposed to having to open up the app, etc.
Hello,
sure, we can try to make a deal with them! Thank you for this suggestion.
Hence, put the GameStop's reward card on the top of your loyalty cards list in FidMe ;)
Aheazarest
