Carstand - anyone using? I have a problem
Vaas
50
I downloaded and installed CarStand. Seems like a good app, however I am unable to use set applications. Also if location service and dynamic background are set, my battery drops fast. It will not last 8hrs before drained, if I disable either one the battery drops fast but not quite, still bad though.
biggest issue though is not being able to set any of the 4 apps. I tap it and it just does nothing.
Hi!
I am the developer of the app. New update should resolve all your problems. To add applications you must hold on a shortcut and select application. Then with tap you launch the application.
niedrie
