Blitz Brigade connection issues
jmaga3080
33
Anyone of you who installed the game have been having connection problems? When I enter the game, several times it gives an error code 1-success. Does it happen to any of you too?
Hello,this problem is here too...but I keep trying to login then it works. My brother plays it on ios and he told me that he's facing that problem too.
yes I have tried 27 times in a row to play the game and every time says error code 1-succes its making me so made dose anyone know how t fix it
Hey friend use any proxy or vpn and then play the game i am 100% sure you will play the game and never see the failed to log or error ok
Hey guys.... i know what is the problem....the problem occurs when the name is in use first i tried simple name "mby" i got that error but when i used a special name "/\/\y" it logged in..in the first try so do try to change the name :D e.g "James" try "#Ja[m]es"
abcdzoony
