Can I get some help with a problem I am having with Here Drive+?
Darknesss75
A problem with Here Drive+
I use Here Drive+ on my Nokia Lumia 925, is super app . I use about 1 year during which he did the job well . But I have a problem. The " Recent destinations " I managed to empty the list by pressing and holding , and then you open a list in which you give the "Delete " on each destination. But when I press the " set destination " appears to me a very long list of everything I 've searched before ... and I have a list of any searches 200-250. They can not erase those on the same method . Is there another way ? As long array that is very annoying . :unhappysweat:
Sportacus11
36
re:
I'm pretty sure this is actually in th wrong folder...but to answer your question, yes you can clear that list
Go to settings
Clear personal data
Clear searchs
And that's it...
DrPendragon
