Lumia 950 problems Word Flow swipe in Edge
brabso
9
Word Flow swipe doen't working properly on my phone.
It does work good overall except in Edge (where i use it a lot).
The problem is if i swipe a word with Word Flow enabled i have to hit the space bar manually to create space between 2 words.
Normally this is working automatically and you don't need to hit the space bar.
Is this a well know problem about Word Flow swipe not working in Edge or is it just me ?
Jeddic
58
When you say "In Edge", do you mean in the URL bar, or in text areas in general? I have noticed that often in the URL I am unable to use Word Flow, but in text entry areas I don't think I have a problem. Maybe it thinks that you are entering a URL so there should be no spaces?
babukapyar
