Hi guys, i've just read something interesting about the standby mode..
https://www.reddit.com/r/Surface/comments/28q496/question_about_connected_standby_on_sp3/
I would like to summarize the post ( maybe some of you already know this stuff but i'm sure that could be useful for others)..so:
With the surface, there are two different standby mode. 1, normal standby; 2 connected standby
With the normal standby, the use of the surface it's like the same of your previous pc, it means that this function is gonna help you to save battery and wake up the surface in the fastest possible way but, once woken up, it is going to update all the app (so it's like it was switched off). The consumption per hour should be less than 1%. You can start this function with the normal options.
2 The connected standby: it's like the standby of our smartphone or tablets like apple and android. It means that the surface is in standby but it is still connected to download mail, news, and other thinks from the web ONLY for the apps, not programs (not desktop app i mean). With this one setting you will loose around 1-2% per hour.
This is not gonna works with torrent software like utorrent that isn't an app. Thus, to use program like utorrent or to download stuff with browser etc.., the best solution should be to create to profile battery settings, one with the options of the standby ON (after, i don't know, 5 minutes) and one with no standby mode to keep on downloading the stuff that u need (don't forget to move from one to an other because, with the standby off, even if you close the case or press the button, isn't going to go in standby mode).
This could be useful for people that would like save more power in standby mode (so take of the connected standby) or for people that need to download stuff (so take off the standby mode and keep on working on the surface with only the screen switched off).
The only one doubt that i still have is: when i close the cover on the screen, or when i press the power button, the tablet is going to standby mode? or it is only going to switch off the screen? Because there's an option in power setting that you can set to going in standby after, for example 5 minute. In this situation i saw that utorrent is still working for 5 minutes so i thing that is not going in standby what i close the cover.
Sorry for the long message but i hope that it could help people to understand the functionality of the surface standby mode.
P.S. Don't forget that after 4 hrs of standby the surface is going to hibernation mode to save more power ( to change it you need to write something in the register). cheers
