Buyer beware: Surface Pro 3 throttling: i7/i5 = i3 in speed with sustained load.
Ruined
487
I am posting this as both a complaint due to my disappointment with the Surface Pro 3 i5 256gb/8gb RAM I returned yesterday, as well as a warning.
The Surface Pro 3 is not a good choice for professional software (i.e. DAW, encoding, etc) I bought it for or games that rely on sustained load capability. With sustained load, the i7 slows down to i3 speeds in short order. The Surface Pro 2 did not do this. Even simple Windows 8 store games run faster on my ASUS T100TA (Atom Z3740, 2GB RAM) than my Surface Pro 3 (i5 4300U, 8GB RAM) on battery due to aggressive throttling.
While the Surface Pro 3 is an ergonomic blessing, in my opinion the higher end CPUs are a bit of a ripoff - unlike the Surface Pro 2, they cannot hold sustained load without throttling down. They may offer slightly faster burst performance, but I am not sure this is worth it for hundreds of dollars more. The $799 Surface Pro 3 is really all I can recommend for people, or the $999 if they really need the extra HD space - because you aren't going to get the most out of the CPU.
This video explains the issue technically using the i7 Surface Pro 3, but it affects the i5 as well - buyer beware!
youtube.com/watch?v=HKh7_9dXYFo
Microsoft Surface Pro 3 i7 Throttle Fail - YouTube
And below, a post explaining the inconsistent experience Surface Pro 3 offers that makes it a bad choice for pro software:
Returning The Surface Pro 3 - Podcast and Blog Posts -
I agree that the $799 Surface Pro 3 is a stunning value and fantastic choice, just be aware you are not getting all that you pay for with faster CPU options. Personally, I believe this is because the Surface Pro 3 chassis/cooling appears it was designed for the more efficient Intel Broadwell CPU which was delayed significantly, likely resulting in the team shoehorning the old Haswell processors into the case with aggressive throttling to make up for it.
Daniel Rubino
Editor-in-chief
Staff member
Jan 19, 2006
1,031
14
38
Also, now that we actually have DATA about the Core i7 version, as opposed to, you know, guessing it'd be the same as the Core i5, the Core i7 appears to throttle less (via Reddit)
Regardless, this whole topic is blown out of proportion, imo.
nasellok
357
Well, my i7 256GB that i picked up on Friday has been stellar so far. It is doing tasks significantly faster than my 3 year old Desktop computer in my office............HP Z600 Workstation with Xeon E5620 @ 2.4ghx, with 8GB of RAM, and Nvidia Quadro 2000 GPU.
I am an Architect, and I dont really care about benchmarks.......so i made my own using the most graphically intense software (other than a game) that I would be using (note - I do not do renderings, I do 3D models, but no lighting / effects - those are all done by consultants):
Booting Revit 2014 with nothing running:
SP3 = 14 seconds
Z600 = 48 seconds
Opening and converting a 200MB Revit file from Revit 2013 to Revit 2014
SP3 = 13 mins
Z600 = 20 mins
Those are pretty good returns to me.............Considering the PC costed 3g's when my office bought it, its a desktop computer, and the SP3 is technically a tablet, and costed half as much $
Ruined
487
Hi Daniel,
Thank you for the additional info - I am aware that the i7 version throttles less with Intel XTU, but it still throttles down to i3 level under heavy load as evidenced by the video in the OP.
I am not trying to blow anything out of proportion, just alert people that the Surface Pro 3 does not perform as consistently as the Surface Pro 2 with the same CPU. I personally bought this both for personal and professional use, and while it is good on the personal side I felt that I was getting less than advertised performance on the professional side. While this might be able to be resolved with firmware, I was approaching the return window and did not want to be stuck with something that did not live up to the advertised specs for more than a few minutes of action. I agree that the average joe would might not notice this (although on the i5 even basic Windows 8 store games were being throttled into stuttery performance on battery), but for those that are buying the more expensive flavors I believe this is something one needs to know before buying into it. I know I would not have bought into it if I knew the performance was throttled to half of Surface Pro 2's performance.
It is a shame because ergonomically the Surface Pro 3 is amazing. Hopefully a firmware fix can improve the i5's throttling to be more like the i7's, but I think this form factor will not truly shine until Broadwell is available.
onlysublime
1,077
you are trying to blow it out of proportion by creating an entirely new thread when other threads already talk about it.
none of this is set in stone. Microsoft can and has changed system behavior through firmware. I'm sure as they get more data in, they'll adjust the settings. Right now, the SP3 does not generate as much heat as an SP2. Most likely because they wanted to ensure a smooth launch. Nothing worse than a bunch of SP3's crashing due to overheating issues. Microsoft has been burned in the past (look at the initial Xbox 360 launch with RROD).
Is it a big issue? Who knows. It hasn't received a lot of press so apparently the masses don't think so. It's just a vocal minority that's speaking about it.
briandwilliams68
6
You might want to dig deeper than a reddit posting. Cameron from cbutters actually followed up that posting with an explanation that his cooler office at work led to improved results. Once he brought his i7 SP3 back home, and tested it in the same conditions as his old i5, it exhibited the same problem. Since this is my first posting, I cannot post a link, but Google "Re: Surface Pro 3 - The problems thread tabletpcreview" and jump to page 67.
This is being marketed as a laptop replacement, worthy of professional and gamer use. The performance offered is only good for moments at a time, and to me, that's not worth hundreds of dollars more. In fact, you can practically buy two i3 models for the price of the i7. Hopefully Microsoft will release a firmware fix soon.
anon(4054009)
124
What kind of programmer would buy a tablet spec low voltage I7 and expect it to run like a desktop with discrete GPU?? Sell/return it buy something else. Right tool for the job,Thanks for the warning
Ruined
487
The Surface Pro 3 does not use a tablet spec low voltage i7 - that is the i7-4610y. Instead, the Surface Pro 3 uses the ultrabook-class i7-4650u, but it apparently does not have the cooling to handle said CPU.
Also, the Surface Pro 2 used similar i5/i7 CPUs and did not have this aggressive throttling, perhaps due to its thicker case. Surface Pro 2 set the ultrabook performance precedent even with intensive tasks, Surface Pro 3 is not living up to it so far. This could change in time with firmware, or not.
briandwilliams68
6
Who said I bought it expecting it to act like a desktop with a discrete GPU. I expect it to run to spec, not under spec... not for that sort of money. The MacBook Air does not have this problem. Apple positions this as your next laptop replacement, not your netbook replacement.
stephen_az
Banned
Aug 2, 2012
1,267
I am confused. So what did you buy? You go on and on about the i7 model but say you returned the i5. You then follow in this post with a reference to SP2s using similar i5/i7 CPUs. I would love to see that SP2 with an i7 given they never made it. Of course you also toss in some laughable exaggeration about things running faster on an Atom device. If that really was the case perhaps you might have wanted to consider an exchange since the device was obviously defective. Yes, I also do have an Atom tablet (Dell Venue 11 Pro) which I am setting up for the office and there is nothing for which it is even close in performance. No offense but whenever I see these posts I wonder why the person even bought the device. It seems more like it was bought for the opportunity to complain based upon other internet posts and then return.
As for the i5 throttling in the SP3, I have experienced no difference in performance between the i5 SP2 and i5 SP3 using CPU intensive Adobe CC applications (more bloated than ever) and ESRI's ArcGIS (as inefficient a piece of software one is likely to find). I can't speak to the subject of games because I don't play them and would be hard pressed to care less. As for work applications, it matches or slightly beats SP2. The only thing that initially slowed it down is the same that has slowed every machine for me since Windows 7. I have thousands of files, including some quite massive ones, that search had to index and (as always) it intermittently killed system performance. Actually that has been a problem since Vista which has only been minimally addressed over the years. Search occasionally draws heavily on the CPU while indexing large/complicated files (or high volumes of files) and does not always release the CPU to other applications as it is designed to do. I expect some other out of box setup elements also still initially hit performance but I haven't bothered to check since the search impact is obvious.
BTW, Microsoft has adjusted CPU optimization with the previous models. Why express ambivalence about whether they will do the same with this device? While I still find the WiFi issues to be a nuisance, even more so since they were created by the update on my SP3, it is hardly the case that Microsoft has been slow in supporting the device. There have already been hardware driver updates and a bona fide firmware update as well. Compare that, and the regularity of updates on all the Surface models Including the ones that have been out for a couple years, to any other hardware manufacturer. There are no rose colored glasses needed when it comes to the subject of future updates.
Dan Strong1
44
Not really... The i7 is a **** ton of money more than the i3 and some are being throttled down to 800mhz!! I was listening to a podcast and the guy returned his Pro 3 because he was getting stuttering while editing voice and video. He said his Pro 2 had no such problems.
The i3 is looking pretty damn good right now in terms of performance and price.
David P2
1,600
You could always go poking in the Power Saver settings and setting it to 'high performance' (so the CPU is forced to max all the time) - if it still throttles, then there is definitely something obscure going on.
ttxzee
169
I think the pro 3 just doesn't dissipate heat efficient enough, the CPU gets so hot it throttles itself. For the old pros you can feel the hot air pushed out by the fans, but for the pro 3, you can only hear the louder fan and feel the back getting hot, there's not enough air flow!
anon(4054009)
124
What I meant to type was a low voltage I7 in a tablet spec. Also where can I buy an I7 SP2? Also confused about the I3 being ok, what happens when one runs the same programs on the I3 that caused the throttling on the I7?
Cause gaming is a Macbook Air strong point, along with the screen quality. I guess the SP3 is running as designed with the thermal management so it is in spec, just not what you want/need. Two very different things. Your last sentence makes no sense.
stephen_az
Banned
Aug 2, 2012
1,267
Yes, and I could have posted a video of how SP2 would overheat and shut down under normal use. Of course I had forgot to turn it off and it was sitting in a car in Phoenix in June. Point being this video is not demonstrating real parameters or confirming a controlled environment and any video that starts by saying why you shouldn't buy something and stresses you are wasting your money pretty much establishes an agenda out of the gate.
briandwilliams68
6
Guys, there are new findings. Cameron found that with a simple box fan blowing on his Surface Pro 3, he can get full performance.
And for those of you saying that an artificial benchmark like Prime 95 is not a valid test, here are my results with Diablo 3, sitting idle, dropping from 47 to 25 frames per second in a matter of six and a half minutes. The frame rate drops even more severely if you are actually playing the game with lots of targets up.
youtu.be / taGIWm-9WPU (still won't let me post links yet)
Would you pay almost $1600 for a device that plays a low-spec game no better than a device costing half it's price? No one is saying the Surface Pro 3 is a failure, just that the i7 edition is a waste of money. The i5 gets you real performance you can feel day-to-day with more storage. Because of the throttling, the i7 won't give you more beyond that.
Cruncher04
227
It was a stupid idea to put an core i processor into such an small form factor device. This includes the i3 as well. It is east math to show, that the TDP of the Haswell processors at nominal clock frequency are far above the possible thermal dissipation possible with this form factor.
It certainly gets even worse, when you give the GPU something to do.
DrPendragon
