I think I'm ready to try Windows 10 on my Surface Pro 3 that I use as my main home computer. I've been using all of the builds of Windows 10 Technical Preview from the very first one on a Dell Desktop and it now seems ready enough to go with. I've also used Windows 10 Mobile on several Lumia phones and don't yet think it's at the same point (I've left it on my 635 but removed it from my daily driver 930).
I know that different methods work better for installing each. On my Dell desktop I started from a totally clean machine. But can I just download and install the latest Technical Preview on to my Surface, or should I boot from a USB iso? Would you create a separate partition? (I know that is the safest way, but I Win 10 seems stable enough on my Dell to risk using on the Surface).
